EB what do you think is so bad about them? I mean yeah they are expensive with good seals but I didn't think they were that bad.You shouldn't replace any more parts until you have made sure that everything is working correctly. Fix the air leaks and reasses
Injectors are a bitch so definitely don't do them unless you really have to
Fair enough, I suppose I'm a bit skewed with what is a "bad job" is on this car at this point. After you pull the motor other things don't seem so bad.Just between removing the manifold and then likely being stuck with factory seals as well as not something that usually goes bad on this platform it's way more work than necessary at this stage
Plus once your in there you would get into cleaning the valves etc.
