GCPhotographers
I have a dipped gen1 VC but I have a genPu. Are there any reliable breathers out there for genjun?
No, as far as I know. Due to not having the baffler on the inside of the oil fill, oil will fill the breather and then leak into the engine bay. I recall a post from PD last week on FB speaking directly to this with the recommendation of vented OCC. Maybe the DM crew can add some knowledge here.
I attempted to make my own with a labrynth seal in it. I failed. It worked for a while, but ended up with oil on the valve cover after a week or 2. The good to know a check valve seems to workWe made one for my dad's speed6 with a built in check valve and after a week it was full of oil and starting to leak. The valve type may make a difference too but that is for keeping unmonitored air out. @bRitzCrackers??
Ziptie that fucker downI already have a dual OCC set up with a vented can. Still lifting the dipstick.
Ran a CFM breather on my gen1 valve cover (have had a gen2 valve cover in storage with a CFM breather waiting to go on but wanted to test this anyway) and I'm currently on a 20k mile motor with 15psi basemap. After 2 weeks of basic spirited driving and short 2nd and 3rd gear pulls on 15psi I got oil on my valve cover and on passenger side heat shield on firewall. After 1.5 weeks I noticed the filter was black, and also notice I have the vent tube VTA'd with a K&N filter to further assist with venting blow by that I installed at same time but even that didn't help. Just my trial results with that suggestion
