Is it time to find another spark plug? I really don't want this to happen to mine.
I was thinking the same thing, but saw "NGK" in the pic and my heart sank a little. Justin (FREEKTUNE) warned me a long time ago about Densos and said he has tons of bad stories about them. I've been NGK ever since.No shit! Wow, that's all a Denso thing. Like all the time.
I never had this issue. They might be slamming the ground strap a little to hard when closing the gap.
OE NGKs must be different because step-colder NGKs come in the 40 thousandths range. They need significant adjustment.I don't know why anyone is slamming the ground strap with the OE plugs. Mine came gapped to about 0.026. Checked every one.
I disagree. Reading your plugs >>> one-size-fits-all approach. I tried stock heat range for a while then pulled the plugs for evaluation. My car clearly prefers step-colder, even with E28 and a CM10 spraying 100% methanol. Not to mention the fact that numerous reputable tuners on our platform recommend 1-range colder on ethanol blends, even on K04s making 50+ less whp than me (for instance). But still, in the end plug reading is the ultimate standard to decide with.Anybody using an E mix should be on stock heat range. You don't gap these plugs and they come standard at .027. Obviously checking the gap is alright, but you don't adjust it.
That's all well and good, but like I said, I literally pulled and read my plugs. I looked at them right there, in my very hands. I was developing black speckles on the insulator that indicated the need for colder plugs, besides the placement of the base timing and WOT timing color shifts on the ground strap indicating the plugs were too hot. I have no misfires at all; never have even a single time. And Justin confirmed by pics I sent him that step-colder are what my Speed wants.If you're reducing the temps in the combustion chamber with E and with meth and then reducing them even more with a colder plug you can have issues with misfires. The knock prevention with E is nice, but if you get it too cold, you're just not going to ignite the fuel at all (sometimes).
Give this a read:
http://www.journeytoforever.org/biofuel_library/ethanol_drane.html#ch7
Compression test went great! Cylinder 3 is @ about 178psi, the other 3 cylinders are at 180-182psi.@Nox
How did the compression test and inspection go?
I didn't have time to scope the cylinder this weekend. I pulled a 4th gear log that I still need to look at/have my tuner look at. Car feels great but thinking I need to seriously consider going ahead and going built. I'll do a leakdown test before I commit to that $4600 motor build. 400awhp @ 123k can't last forever.
Sent from my Nexus 6P using Tapatalk
All of the NGKs I bought came gapped correctly.This thread makes me nervous. I just gapped some ITV20's............ What's the best way to bend the ground strap? My tool has a little slot you stick over the strap an pull down.
That's because I believe they are gaped for a CTS V or something like that.OE NGKs must be different because step-colder NGKs come in the 40 thousandths range. They need significant adjustment.
