that must be nice. The desnos came at like .04"
I would stay away from Densos if I were you. A few people have this issue with them. I'd swap to NGKs ASAP despite me having some shit breaking off of my set lol.
If you really suspect an imminent ZZB and have objective data to support it (compression/leakdown, and especially pulling the oil pan and putting eyes on your rods to confirm no deformation), then best to run de-tuned power levels to stretch service live rather than building an engine due to a vented block you can't re-use. It'll potentially save a lot of money too...We're in a similar boat man. 121k for me as well. I've been just piecing my build together for the imminent boom. You have a lot more shit to break on the 6 though lol!
Compression and everything looks good, but not-stock power on an older engine is what I'm worried about. I have no issues currently and I haven't spent any money, I've just been weighing my options and thinking about the "what if" situations.If you really suspect an imminent ZZB and have objective data to support it (compression/leakdown, and especially pulling the oil pan and putting eyes on your rods to confirm no deformation), then best to run de-tuned power levels to stretch service live rather than building an engine due to a vented block you can't re-use. It'll potentially save a lot of money too...
I'd definitely recommend getting eyes on your rods. That'll be very telling. Relying on seeing knock or clutch pedal vibes before rod failure sometimes lets you know it's impending, but not always. Other things could happen too, like a spun bearing.Compression and everything looks good, but not-stock power on an older engine is what I'm worried about. I have no issues currently and I haven't spent any money, I've just been weighing my options and thinking about the "what if" situations.
Have any UOAs? Hows oil consumption?
I've had to gap every single set of spark plugs I've bought. .026All of the NGKs I bought came gapped correctly.
http://edgeautosport.com/ngk-laser-iridium-spark-plug-iltr6a-8g/
Agreed. Autolites or NGKs. Autolites for availability while waiting for NGKsI would stay away from Densos if I were you. A few people have this issue with them. I'd swap to NGKs ASAP despite me having some shit breaking off of my set lol.
No oil consumption here either. May our boats both float on the stock block for another 50k!No oil consumption. Have my first sample over at Blackstone now actually.
	Damn that's lean as fk. Dually noted -thank you.
Have you inspected them since? That's nuts.
Also make sure to rule out PCV problems. Make sure all your check valves and lines are clean and working.
It's also possibly the turbo itself. When we pulled my original K04, it was leaking liquid oil out of both the intake and exhaust sides.
Isn't the captive gasket alone sufficient? Pretty sure that's how it was designed from the factory, right? Or is excessive blowby too much for that gasket on higher boost applications?Running a perm plate and I've made sure that everything was tight, but I didn't end up RTVing it down (pain in the ass). I did get a new gasket when I installed it though, which wasn't too long ago.
Liquid out of both sides, this sounds like a Nator AZ meet...
