gotovato
I won’t be messing with bias/prop valve. Stock bias is about 70/30 front to rear. The master cylinder is an oem part from an Acura TL type S. Directly bolt on. No modification required and no bias modification required. The stop tech big brake kit is also designed to retain bias. My reason for the larger master is for when I get the brake fluid a little over temp(I often tend to) having the larger master will mitigate some of the pedal squish/softness I always had and hated with the Mazda. The pedal will be super firm and responsive otherwise. Should be interesting. If it’s an issue I’ll just go back to the stock. This is more of an experiment. When people do the Acura TL brembo upgrade on the civics it’s leaves them with a soft pedal. The answer is upgrading the master. We’ll see how it goes.Are you going to use a adjustable proportioning valve? What kind of bias does the Civic have?
I will have to try a few different rear pads however to balance out the hawk dtc-70’s that’ll be going up front. There’s a method for figuring this out but it’s some trial and error on track.
