Have you considered making a Raspberry Pi Dash using Tunerstudio or some other form of windows software? I bet you could get Hondata to work on it even
this thought did cross my mind but then I also started thinking about telemetry collection and lap timing.
Could something like that be integrated into the Pi?
I’d also like to have it be able to intercept my canbus signals so I can have all the oem shit displayed there as well. Not to mention inputs for additional sensors. Not even sure where I’d start for that.
The GoPro telemetry is what I use for my videos now. It works ok but the gps is nowhere near a dedicated lap timer. The accelerometer isn’t the best either.Use a GoPro and race render. It uses GPS data to sync your track videos with map data. As for g readings you'll need data logs to add to race render but the software takes a lot of file types. I was able to use my Megasquirt data logs with videos no problems. I know HPTuners and others work as well.
Hahahahaha"See how this OEM angers aftermarket companies with this one weird trick!"
Honda has been perfecting their recipe since inception. Spending a little more time designing simple tech and refinement allowing reduction of excess material and weight = cost savings and reliability leading to lower warranty claims. In your case its simply all win!!I don’t want to upset anyone but this is why Honda’s make power. Right here...I guess Honda has a reputation for a reason. I love it lol.
It really is ridiculous. Even the oem intake manifold is a total fucking beast. Flows literally all of it. Like ALL of it. Then you look at those head ports and it’s like…they designed this for something specific. Yea it’s a cheap ass commuter car sure…but that motor ain’t no cheap shit. Someone did a lot of math here.Honda has been perfecting their recipe since inception. Spending a little more time designing simple tech and refinement allowing reduction of excess material and weight = cost savings and reliability leading to lower warranty claims. In your case its simply all win!!
I really don’t know either. People port these heads all day long but a shop wants 1500+. Or you go CNC port and you’re like 2k+. For a balls out NA build I can see that being a huge help but if I boost this thing down the road…which we know I will…like how do you improve on those ports? Some guys cut the valve guides flush to the casting and smooth it all out. Apparently this is fine lol. More heat into the valve though so I’ll probably avoid that for now but yea. DamnOther than a gasket match I don't see how you would make that better
Yup. This would be exactly why. It’s also why it’ll make 400whp and 280wtq with like no boost. The Honda dyno graphs are pretty nice.One other thought on the intake port though. I now see why Honda's don't make any torque
Apparently the exhaust side can use some opening up. That’s mentioned. Hog the exhaust side out. Otherwise yea these cars like a lot of exhaust flowAt those flow levels its probably exhaust and hotside work you need, not head porting.
