How much gas is in the tank if under half just fill it up with fresh gas and let the car run for a bit. Gasoline is a fantastic solvent and will wash away the varnish that has built up from evaporating gas
I keep forgetting to check. I believe its around 115k. I'm wanting to get the whole car set to be a daily asap, so I think that rebuilt from CW might be the best bet for the budget. Otherwise I'm looking at off-brand turbos to be able to stay within budget, but that PCV valve is only $30 so I will give that a try before replacing the turbo.If timing chain is slapping it's a full timing job what's the mileage?
Turbo is full rebuild, if you want an OEM one I'd say get a rebuilt one from CW https://www.cwturbochargers.com/pro...1&_sid=5d0abbc63&_ss=r&variant=43238857146583
Dang Timing looks like a much bigger job than it was on my B5 S4. I'll read through that a couple more times and see if it's something I want to tackle myself. If I'm troubleshooting the idle smoking anyways, should I just use the PP 5w-40 on this initial oil change? Or do you think it would be worth it to see if the PCV fixes the smoke first? PCV valve comes in Wednesday, looks like sort of a PITA job, but not smoking at red lights and drive-throughs is worth it lol.Timing service is 15k overdue so if you're suspicious of it definitely time for a timing job imo. Now 5w40 can bandaid the turbo if crank case ventilation is sorted.
Timing how to: https://mazdaspeeds.org/index.php?t...eed-3-mazdaspeed-6-cx-7-vvt-the-roku-way.855/
Our oil thread: https://mazdaspeeds.org/index.php?threads/best-engine-oil-all-mod-levels.7931/
I'm looking into this PCV valve replacement, seems easy enough but someone did bring up a retaining clip that can get damaged that holds the pcv valve to the oil seperator. Do you know if it is this part by chance? LF01-10-509 https://www.tascaparts.com/oem-parts/mazda-pcv-valve-retainer-lf0110509Most common cause of smoking turbo is poor crank case ventilation not actually turbo seals, altho that can be a symptom of it, probably pcv valve. Not sure what oil you're using but please don't use rotella.
As for turbos only one really doing rebuilt OEM is Chris ward turbo chargers but for that cost I'd jus they a bnr turbo s1 or s2 one of them is drop in, s3 if you want more pep that'll need hpfp internals and a tune tho
How much have you driven it since it started running are you still on old gas? Have you checked the spark plug gap? Does the battery have a full charge and I mean check with a voltage tester not just strong enough to start the car
Would chem soak get the valve faces? I notice in the write-up they said not needing to fill the cylinder, but valves are at the top? Or is the fluid going to climb up to the valves? I don't see any reason why you couldn't, so could you just fill it so you're sure the valves are exposed to the cleaner? Or is spinning the crank one full rotation going to expose the valves to the cleaner enough to break down the carbon?wonder if it's carbon from sitting, some folks have had success with a chem soak https://mazdaspeeds.org/index.php?threads/another-piston-soak-success.16255/#post-114533
gotta get that fresh gas in there as well
