So tomorrow I'm going to try a few things.
Check torque on pcv plate, injectors, st manifold, and check pcv hose to mani.
I'm also going to test the split second controller and make sure its getting power and getting maf voltage and rpm readings. Maybe reflash the map to make sure its good.
I'm also going to remove the Damond Motorsports vented can and hook the big OCC stright to motor and hope i don't get any stft issues(rough idle).
But I had a thought. So when I pulled the spark plugs to change over to a fresh set with new gap. I found the plugs that were in there, the insulation had cracked. Big time. I didn't think much about it. SInce I was already changing the plugs. Here is a few pictures of the plugs i pulled out..
View attachment 17333 View attachment 17334 View attachment 17335
But after the plugs were changed, its been consistently popping and back firing. So I thought maybe the plugs were bad, but the change in gap was not needed yet.
So when I did the plugs the 1st time I used a standard disk gaper. But was only able to get .020 (thats the lowest setting on disk gapers) after I read a few things online, I realized with NGK Iridium plugs your not supposed to use the disk gaper because it will damage the Iridium tip and basically trash the plug. So I bought a second set and a different gapping tool. And gapped it the correct way. But gapped it to .018 this time.
So moving forward, I took the 1st set of plugs that I had that I used the disk gaper on and I re gapped them to .022. The original gap the I was to put them to at the start of the tuning process. And went for a drive and I was able to drive aggressively and go well into boost. But it slowly started doing it again.
I was able to get a few logs. Now correct me if I'm wrong but if you compared the logs I sent to Justin on E33 map B to these ones. I think my PI is not coming on. The map B logs show the target A/F around 11. And my new ones shows the A/F all over the place. But your seeing 12's, 13's and 14's while at high boost and the 14 at high boost I hit 5.+ knock and thats when the car was popping and hesitating.
I'm going to re gap the good plugs(2nd set of new plugs- gapped to .018) to..022 just so i can eliminate the 1st set of possibly bad plugs (used wrong gapping tool).
Here is the logs from tonight with the only change being putting in different plugs but gapped back at original gapping. And there's a log of the car at idle.
