DualSpeed
If that's the way they are, I'm ok with that. Just trying to improve what I can. ThanksBalancing the internal components of the motor has nothing to do with the inherent harmonic imbalance of an inline four cylinder.
Thanks for the input, I appreciate it! So what amount of camber front& rear do these cars like? Stock on the front looks pretty straight up and down, maybe a little positive.Highly recommend both. If you can find a turbine tech style front mount, get it - the extra mount points prevent the 2 main bolts from breaking the case. You smack the throttle on and off more often in autocross than you do on a strip.
Adjustable ball joints in the front - yes. There's no other camber adjustment available.
For the rear, you have camber adjustment on the LCA via an eccentric bolt, and it's good for a little bit of camber. Once you get into the realm of 3°+ of camber, you need adjustable uppers back there. I wouldn't get them until you run out of adjustment on the LCA.
Suspension compliance is a good thing. Letting the suspension work while controlling camber loss is forever the goal. Just remember that the stiffer the ride, the more load variation the tire sees - tires hate sudden load changes and it reduces grip...
Ok, I'll be ordering the adjustable upper ball joints, then start playing around with it. I used to work at shops where I did all the alignments, now I have to pay for them. I might have to get my own setup, and save the hassle. Where I live it's 200 bucks for an alignment!!Peak lateral grip will be found somewhere north of -2.5° camber. You'll have to do some testing to optimize it front and rear.
I thought I'd give an update. Been working nightshift for the last 14 nights, it's been raining non-stop here..... The car has been working flawlessly. Great power, fuel mileage, the AWD in the rain is fantastic! So many people that I talk to are really impressed by the car.
Still waiting on more parts to show up. phate what info do I need to gather to start picking out shocks and springs/coil overs, and swaybars?
Also wondering on tire/wheel combo, and fitment?
Ok, I'll figure out a place to get the 4 corner done. Nope, not ready for the chop shop yet..... Though I'm sure I would like the handling!! Right now the first step will be 245/40 ZR 18's. Just because that's what I have to sort it out. The poly bushings, ball joints and shocks/springs will be at the same time.I would start by getting corner weights for the car at race weight (with driver in it, as much fuel as you would run with). From there, you can calculate spring rates based on sprung mass frequency (I'll break out my spreadsheet since it was lost to the public when MSF went down).
Wheel/tire - you can fit up to a 335 on a 12" wheelJust depends on how much you want to cut. With a good roll/pull, a 255 on a 9.5 +43(ish) is a good fit.
Hey @phate, where did you get your scales from?Ok, I'll figure out a place to get the 4 corner done. Nope, not ready for the chop shop yet..... Though I'm sure I would like the handling!! Right now the first step will be 245/40 ZR 18's. Just because that's what I have to sort it out. The poly bushings, ball joints and shocks/springs will be at the same time.
Ya, I hear you!! I'll keep my eyes open for something.Friend of a friend, who bought them used to begin with. Scales are very hard to come by second hand...
Nice! I'm trying that route now. So far all we're coming up with is the Driveshaft Shop boots. Hoping for a cheaper, local source!I had to rebuild axles for my Starion years ago and I just took the axle apart then went to a local parts store to match it up to whatever ones they had there. Turned out to be fairly cheap as I only spent 30 dollars to reboot two axles.
